2−9−3. ATIS CONTENT
EXAMPLE−
“Boston Tower Information Delta. One four zero zero Zulu.
Wind two five zero at one zero. Visibility one zero. Ceiling
four thousand five hundred broken. Temperature three four.
Dew point two eight. Altimeter three zero one zero.
ILS−DME Runway Two Seven Approach in use. Departing
Runway Two Two Right. Hazardous Weather Information
for (geographical area) available on HIWAS, Flight
Watch, or Flight Service Frequencies. Advise on initial
contact you have Delta.”
It says wind 25010 am I missing something somewhere?Ha, that's kinda funny.
It's in a weird order and uses some unsusual phraseology too. I think that paragraph might be grossly out of date. I've never recorded an ATIS using Fahrenheit temperature, I'm not sure where/why that would be the norm.
Interestingly, the example provided in our ATC manual has a peculiar temperature as well. It's not impossible by any means, but how often is Boston running a 34deg C fever?
Also, wind 14010KT and landing RY27, Departing RY22. I think the guys that write these ATIS notes are trolling us.
Scottsdale ATIS is usually the time, wind, temp and pressure. Caught off guard by it and had to listen to it multiple times.And to add my own question to this, from the AIM it says that the:
The ceiling/sky condition, visibility, and
obstructions to vision may be omitted from the ATIS
broadcast if the ceiling is above 5,000 feet and the
visibility is more than 5 miles.
Does that mean that the atis doesn't even need to say "weather better than 5,000 and 5?"
For me it throws me off my rythem and I need to listen again. Even saying better than 5 and 5, it's just not what I'm expecting. 10 and clear below 12 is my preferred way of hearing "nice".Correct. The 7110.65 says the same.
In my experience, if you omit it, pilots will ask because they're curious or think that the omission was in error.
