88MPH
Addicted voyeur
This is from ASA CFI Prep.
"True airspeed and true altitude are based on the existing outside air temp, which affects the density of the air. While flying at a constant power setting and a constant indicated altitude, an increase in OAT will cause the air to become less dense. Both the true airspeed and the true altitude will increase."
I understand that higher temp makes the air less dense, so you're altimeter/wings will interpret that as being at a higher true altitude, when it's just density altitude.
What I'm not getting is "while flying at a constant ... indicated altitude ..."
Theoretically, if you can hold TRUE altitude, altimeter should indicate climb in warmer, less dense air. But if holding a constant INDICATED altitude, you would have to decend the plane in response to the fooled altimeter.
I don't think it's a typo, as its repeated in the book. What the H-E-double-hockey-sticks am I missing here???? :banghead: :banghead: :banghead:
