jrh
I've recently run across a performance oddity that nobody has been able to explain. I've spoken to several friends, senior pilots at my company, and even a check airman at a major sim center and nobody has come up with a good explanation. In fact nobody had even noticed this oddity until I asked them about it.
Looking at the takeoff distance charts for one of the planes I fly, one would expect to see takeoff distances increase with ambient air temperature, all other factors remaining equal. This is exactly how it works at higher gross weights. For example, at roughly 16000 lbs, for a given set of conditions, you might see something like this:
-20 degrees = 3000 feet
0 degrees = 4000 feet
20 degrees = 5000 feet
40 degrees = 6000 feet
Obviously these are fictional numbers, but you see the trend...warmer air requires more runway, which is what most pilots expect.
Now, the oddity starts appearing as gross weight decreases. At a "mid" gross weight, say, 13000 lbs, you'll see a small, momentary reversal during a range of temperatures. It looks like this:
5 degrees = 2600 feet
10 degrees = 2800 feet
15 degrees = 2700 feet
20 degrees = 2750 feet
25 degrees = 3000 feet
See how if you were to graph this, it would look like an "S" in the graph?
Continuing to an even lower gross weight, at the very light end of the spectrum, say, 10000 lbs, you see something extremely odd:
-25 degrees = 2200 feet
0 degrees = 2500 feet
40 degrees = 2600 feet
50 degrees = 2200 feet
54 degrees = 2100 feet
See how a graph would essentially be a "hump" of some kind in the middle of the temperature range? What's even more bizarre, you literally get better takeoff distances at +54 degrees than -25 degrees.
Again, I've made up the numbers in this post, but the trend is what I'm talking about. It occurs regardless of field elevation.
Any idea what causes this? Considering it only happens at lower weights, I suspect it has something to do with the power to weight ratio.
A friend suspected it might have something to do with braking action being relatively constant across the temperature spectrum, yet vast differences in power available, therefore at the cold end of the spectrum the balanced field length is more dependent on the braking ability, whereas on the hot end of the spectrum the distance is more determined by the power available from the engines. I noticed V1 is constant at cooler temps, then begins dropping several knots at the upper end of the temperature spectrum.
Seems odd to say, "It's too cold to takeoff, I hope it warms up a few degrees," but that's exactly what I had to hope for the other day!
