NewsBot
Administrator
M1 Support Services Meridian, Mississippi:<BR />Primary Responsibilities:<br />• Brief, plan, and conduct ground and flight tests of aircraft.<br />• Perform preflight, in-flight, and post-flight procedures, functional checks, and maneuvers in accordance with flight operations procedures, FCF checklist and other applicable publications. <br />• Maintain currency and proficiency on tasks/maneuvers required by applicable Naval instructions, the T-45 NATOPS instructions and other related publications. <br />• Maintain thorough knowledge of aircraft systems, emergency procedures, operating limitations and restrictions, regulations, publications and established procedures. <br />• Perform thorough preflight pNAlanning which includes, but is not limited to, filing flight plans/logs, and computing and evaluating aircraft performance data, weather information, notices to airman (NOTAMS), fuel requirements, and weight and balance data. <br />• Review aircraft maintenance forms/records to determine the checks required for functional check flights (FCF) and maintenance on the aircraft has been properly performed and documented. <br />• Briefs crew and passengers on specific mission, normal procedures, emergency procedures, and equipment requirements.<br />• Performs cross-country aircraft ferry and rescue operations.<br />• Prepares, maintains, and completes forms, records, reports, and other related documents pertaining to aircraft maintenance in accordance with applicable technical publications and other directives as required.<br />• Participate in training to increase knowledge and job skills.<br />• Comply with established general and industrial safety rules and regulations as applicable to the contract, facilities and job assignment.<br />• Assist as directed to ensure safety, security, and preservation of Government/Company owned equipment and supplies.<br />• Work and communicate with internal and external clients and customers to meet their needs in a polite, courteous, and cooperative manner. Plays an active part in problem resolution and is committed to quality service.<br />• Perform other related duties as required. <br />Requirements:<br />• FAA commercial or Airline Transport Pilot certificate with an instrument rating with single engine privileges.<br />• FAA Class II medical certificate.<br />• Minimum of 2,000 fixed-wing flight hours.<br />• Minimum of 500 T-45 flight hours.<br />• Current or prior FCF qualification (any military aircraft).<br />• Capable of completing Naval Aviation Survival Training (Aviation Physiology and Water Survival).<br />• Meet all anthropometric requirements for the T-45.
Continue reading...
Continue reading...
