AnBok
[FONT=arial,helvetica,sans-serif]Minneapolis/St. Paul, MN Corporate Offices as Aircraft Dispatcher
Responsible for executing all assigned flight operations in compliance with FAR's and company procedures and policy. Primary duties include pre-flight briefing of crews on current weather, NOTAMS, and field conditions, distributing flight plans and flight releases, re-routing flights as necessary, calculating of appropriate fuel loads, coordinating with the maintenance department in regards to maintenance and MEL's, following flights, updating flight crews to any unforeseen weather conditions, revising Jeppesens, and all other department manuals; and any other duties assigned by supervisory personnel. [/FONT]
[FONT=arial,helvetica,sans-serif] Primary Responsibilities:[/FONT]
[FONT=arial,helvetica,sans-serif] Qualifications[/FONT]
http://www.suncountry.com/hometools/aboutCareers.shtml
[*] Responsible for flight planning, dispatch releases, operational control, and flight monitoring of all flight operations within his/her assigned route system
[*]Responsible to ensure the information necessary to perform flight dispatch duties is available and current at the start of his/her shift
[*]Knowledge of current and forecast weather
[*] Bachelor’s Degree preferred
[*]Valid FAA Aircraft Dispatch Certificate required
[*]2 years Dispatch experience preferred
[*]1 year Part 121 Domestic/Flag dispatch experience required
[*]Excellent computer skills
[*]Strong knowledge of applicable Federal Aviation Regulations, weather and technical dispatch skills
[*]Must be flexible to work all shifts including weekends and holidays
[*]Qualified candidates must pass a criminal history background check
