Heh.
Just to be clear, the cockpit crew WILL use oxygen, but absolutely do not feed the rear oxygen.
On the airplane I'm currently on, there are like 3 different bold print warnings not to let the cabin exceed 13,500 ft because the masks will deploy.
However.
We are allowed to manually depressurize the cabin slowly so to pull smoke out of the cockpit. Basically, PRESS CONTROL... MAN MAN ALT... UP MAN RATE... INCREASE AS REQUIRED, HOLD, WHEN SMOKE HAS CLEARED.
You'll have to do it a few times.
At no time does it indicate, nor would a do, a big old pressure dump.
