durind
I recently was doing local approaches at an airport close to the aircraft's home base. We did a few approaches then attempted to head back to our airport but found that fog extended until about 600 feet off the ground at the airport we had been doing our approaches at blocking us from our home base.
Now, the airport we were doing approaches at is on a 600 foot hill and this hill extends only about 3 miles towards our airport before it drops away to a valley which is at sea level. Another instructor requested a special VFR and just went underneath it, but the entire area between the airport and home base is most definitely congested.
Someone tried to explain to me that if you are in the terminal area of an airport that the altitude minimums don't apply, but the way I see it, it would only be if you landing at that airport, whose terminal area you are flying low in.
So essentially to boil down my question to one sentence, can you ignore minimum safe altitudes if you are on a special VFR clearance, very clearly within the terminal area of an airport, but NOT intending to land at that airport?
