Southwest test
Wolfman14
If anyone takes this day
I have a couple of questions about test.
How many questions and how much multiple choice any wind aloft questions or airport lighting
Wolfman14 said:
If anyone takes this day I have a couple of questions about test. How many questions and how much multiple choice any wind aloft questions or airport lighting
Wolfman...no disrespect but seriously - just study. You'll be fine! Nobody can take the test for you. Just know your stuff! You had to pass the written, oral and practical. If you can do that, you certainly have the ability to pass a pre-employment test given by an airline. Just put forth the effort and study. You can do it! Best of luck. ;-)
I'll say this. Study all of those things you mentioned.
There is nothing on this test you don't already know if you've been dispatching any length of time. It's not designed to be tricky or misleading or otherwise try to twist you around the prop. It is thorough and will make you think. It will also judge your ability to work under time constraints. So try to relax and go with your instincts. Getting too lathered up about this is only going to work against you.
