MusketeerMan
Going to hire 100 pilots.
The application window will be open for two weeks ending March 23. Candidates will be selected for interview based on competitive experience. In-person interviews will be held in April and May.
Process:
Candidates apply through southwest.com/careers, answer prescreening questions, and upload a simple résumé. We recommend that the résumé be created in a Microsoft Word document and then attached at the end of the application process through southwest.com/careers. Candidates who meet minimum qualifications for employment will be e-mailed a link to create a detailed profile.
The minimum requirements for consideration:
USA DOT/FAA Airline Transport Pilot Certificate (ATP).
2,500 hours total flight time or 1,500 hours total flight time in a turbine aircraft.
A minimum of 1,000 hours in a turbine aircraft as the Pilot in Command. Only time in a fixed wing aircraft is counted toward this minimum; this specifically excludes simulator, helicopter, WSO, RIO, FE, NAV, EWO, and UAV.
Actively flying for two of the last five years preferred.
High school diploma or equivalency required.
Four year degree from an accredited school desired.
B737 type rating is not necessary for interview, but will be required for employment.
Process:
