Cessnaflyer
Wooooooooooooooooooooooooooooooo
We are flying over Bozeman with Salt Lake right now and he was saying they are installing new solid state radar. What are the improvements going to be with this system?
Radar of any kind will be all but gone within 15 years
Except maybe military prime
I just think since ADSB is literally 15x cheaper to buy and requires little to no upgrade or change to display functionality, why wouldn't it?Not sure where you control but our flight data system in the US resembles a Commodore 64. Our voice lines at least where I'm at run on DOS. The most high tech I have either runs on windows xp or is by now low end walmart hardware.
Radar may be obsolete in your country in 15 years but not mine. Heck we just started running a multi site fusion radar here in anticipation of ADSB. That's the latest and greatest right? Ever seen a jet move backwards on final? That's now a daily thing for me.
We're putting some on satellites so we will hopefully have surveillance and "radar"'separation standards everywhere, no more missed coverage areaS
Umm...I don't think anyone suggested that primary military radar is going away.And what happens when an aircraft loses its electical system, or there is a gps outage? How do you defend the ADIZ? Radar isn't going anywhere.
?? Prime radar is not how aircraft are controlled, at least in majority of countries, if you lose all electrical you lose transponder and more importantly radios anyway.And what happens when an aircraft loses its electical system, or there is a gps outage? How do you defend the ADIZ? Radar isn't going anywhere.
Maybe you guys get drop feeds from all military prime?
I should say our terminal units do as well in order to provide 3nm separation.Primary radar is absolutely used in US Terminal facilities. It's used in conjunction with secondary surveillance radar, yes, but the primary return is a very useful portion of our radar presentation on the scope. Also it's what sees the precipitation we call out to pilots.
Go back to shrimp boats!Procedures don't separate airplanes, controllers do. I would never be comfortable working without primary radar...
This technology however you can have so many redundant systems in sure it would be easy to give the same level and even better surveillance.
If one airplane drops all electronics, which is rare enough, we have procedures in place for that.
Procedural separation
Well I'm assuming you guys have PERF scenarios, radar outage scenarios?I'm guessing you've a NAV Canada Centre controller. Even if I'm off base I'm sure you fall in to the Center controller profile and other than FAA but first world nation box. I'm an FAA terminal RADAR guy just by way of explaining my level of understanding. We don't exactly have the capability of running GPS direct/lost comms/he's just going to plug away the last 700 miles of his trip/no idea if he's ever landed because he disappeared from my scope 5 hours ago due to an ADSB failure. Dropping all electronics in the IFR environment is an emergency. A Cirrus with a failed or poorly made transponder (analogous to ADSB requirement) is a monthly event. The FAA ARTCC types can comment more on their ability to run non radar on GPS direct routes in the flight levels on a seconds notice though.
Strictly speaking from a TRACON standpoint, are all non ADSB equipped aircraft to be barred from class C or B? How will PRM approaches work? I don't think satellite update times will ever be better than hardwired forward facing PRM.
Well as I eluded to, as time goes on the technology will improve, and/or it will be replaced or supplemented by even better technology.Procedural Separation relies on pilots making accurate position reports. Lost electrical = lost position reports.
I am an oceanic en route controller. One of my off-shore radar sectors utilizes a mosaic of 5 different long-range radar sites. The airspace is not designed for procedural control, since the probability of losing 100% radar coverage is nearly zero, and chances are if we did lose 100% of the radar, it is also likely we would have lost our frequencies as well. Additionally, the ADIZ runs through that particular sector, and if an aircraft entering the ADIZ is not radar identified within a few miles of our boundary, Eastern air defense is on the shout line wanting to know who it is. We don't even need to have a discussion about an aircraft that does not want to be seen.
If an aircraft loses its transponder, we can still radar identify and tag a data block to a primary only return if necessary. If we were ADS-B only, and an aircraft lost its electrical system, there would be no way to separate it. At least with primary, we could keep all other traffic away from the primary return. In the event the aircraft only lost ADS-B out, the only way to separate it from the rest of the aircraft in the sector would be to use vertical separation. Our other off-shore sector is located on an island with secondary-only radar. That airspace is designed for procedural control, and we use it quite often for both scheduled and unscheduled radar outages, but without two-way radio comms, that would also be impossible.
Additionally, as an oceanic controller, I probably have more experience with the use of ADS around here than anybody else, and I can tell you that although for the most part it is fairly consistent, it doesn't even come close to the reliability of radar or HF radio communication. It is true, some of that lack of reliability is due to satellite outages and solar flares, but a lot of it is equipment malfunction or configuration on the aircraft or with the flight plan. HF radio for trans-oceanic operations isn't going anywhere any time soon either.
