Slow/crashes in safari for iOS
Roger Roger
Bottom of the list
Ever since the changeover, I've been experiencing intermittent slowness and occasional crashes in safari for ios on my ipad 2. The forum starts out working at normal speed, then gradually gets slower...longer page load times and delays in text appearing while typing, then eventually safari just crashes. When I reopen safari, it's back to normal speed for a while, but the cycle repeats.
clear the cache/ cookies. Sounds like some form of it is causing a memory leak/ issue.
iPad or phone?
If that does not work, restore the iPad. If the cache is not bad (a one time thing) then Safari could be corrupting the data as it being written (happens but rarely).
Still getting random crashes in safari after the upgrade to iOS 5.
That is odd. 90% of the time I'm on the forum, I'm using Safari on the iPad.
Which "skin" are you using? Mobile, Dark or the Jetcareers/Default?
Why not get Tapatalk?
Because I'm a cheapskate.
Dark. It crashed 3 times consecutively trying to make this post on my iPad, each time right after I hit "enter" to move the text entry down a line after my quote from darren's post. Now on my wife's MacBook and it works fine.
Erg. Exactly why I was reluctant to add an alternative skin because one has to play "Whack-A-Mole" with problems. Does the problem occur with the default/jetcareers skin?
Nope, don't mind, but prolly won't be till tomorrow... iPad battery is dead and other passengers are hogging all the outlets in the boarding area!
