Single engine piston 135 ride.
Douglas
Old School KSUX
The flight express guys and the Ram Air guys here can probably answer my question.
Q: After you were hired on with your company, how many training flight hours did it take before you were ready for your initial 135 ride, Single engine piston?
Thanks
-Douglas
that seems pretty hardcore. though i guess it's understandable
Not really... when you get hired you should already know how to fly, know the regs and procedures associated with the type of flying that you are going to do, and you should be prepared to take a checkride the day you show up for training.
I took a 135 ride in a Metroliner after 6.7 hrs of in aircraft training. I am sure other places have similar training programs.
I got 3 hours in a PA32 but that was VFR 135.
For my VFR 135 gig, I showed up, flew with the CP on a relocation part 91 leg, flew a couple of empty legs for 2 or 3 days, and then took the checkride. About 5hrs or so from zero to hero with them.
6.7 hours in a Metro? That's gotta be some kind of record.
For S/E, it was 3 hours and check for the PA-32/32R, then a quick differences for the C-207/T-207.
Was a little more in-depth when I went to the 208, but that was more an aircraft transition vs a new or initial 135 ride.
Ahh...that makes more sense.
What company did you do it with? I thought most operators flew their Metros single pilot.
For a Part 135 checkride is like a normal FAA checkride that is split into one part oral and one part flight portion? Or is it just a flight portion
Merlin Airways.... they are no longer is business because if they were I would still be down there... their op specs called for two pilots when flying into venezuela... good times.
