3-4-10. RUNWAY EDGE LIGHTS
Operate the runway edge light system/s serving the
runway/s in use as follows:
a. Between sunset and sunrise, turn the lights on:
1. For departures. Before an aircraft taxies onto
the runway and until it leaves the Class B, Class C, or
Class D surface area.
2. For arrivals:
(a) IFR aircraft-Before the aircraft begins
final approach, or
(b) VFR aircraft-Before the aircraft enters
the Class B, Class C, or Class D surface area, and
(c) Until the aircraft has taxied off the landing
runway.
b. Between sunrise and sunset, turn the lights on as
shown in subparas a1 and a2 when the surface
visibility is less than 2 miles.
c. As required by facility directives to meet local
conditions.
d. Different from subparas a, b, or c above, when:
1. You consider it necessary, or
2. Requested by a pilot and no other known
aircraft will be adversely affected.
