RNAV stuff is now domestic ICAO data.....
So before the switch a Boeing 767-200 without GPS in the FMC (and no RNAV approach OpSpec) would be filed as either H/B762/J or H/B762/Q. Now that same aircraft is: B762/H-SDIRWZ/C and NAV/RNVD1E2A1 (indicating RNAV SID/STAR and Q/T Airway approval).
/I is basic RNAV without RVSM.
Hope this helps.
You're close..... those things you are talking about is the new PBN/ part of the ICAO 2012 changes. So if the airplane had RNP10 certification as well as RNAV SID/STAR/Enroute it would be: PBN/A1C4D4. One of the theories behind the new PBN/ item is exactly for this scenario because the PBN/ codes include RNAV(GPS) and RNAV(RNP) approach identifiers as well the regular RNAV en route stuff.I only know the NAV/ codes that pertain to my operation, but even my slightly inebriated self knows that the A1 portion means RNP10 qualified. Not sure if RNAV equipment implies RNP10 but I am pretty sure it does not. I would need my cheat sheet to know what D1 and E2 mean.
Depends...... always read the chart notes. If you're talking about ICAO PAN-OPS constructed procedures, they always include the updating requirements in the procedure notes (e.g. GNSS only or GNSS - DME/DME - VOR/DME).Just out of curiosity, could you fly an ILS approach that requires RNAV capabilities? We have a few of those.
Welcome to ICAO.It is very confusing. I put in he aircraft info and fltplan.com spit out -SDGRZ/P PBN/B2C2D2 NAV/RNVD1E2A1.
The D1 and E2 and, for that matter, A1 that I talked about above are part of the NAV/ input.
So it would be: B762/H-SDIRWZ/C NAV/RNVD1E2A1 PBN/A1C4D4
Confusing aint it
That is what is commonly done, but I was looking for the correct way. /G explicitly includes approaches./G. If they try to give you a GPS approach just tell them "unable."
No need to get overcomplicated.
Sent from my Nexus 7 using Tapatalk 2
You have no idea how many times I have been cleared direct to something 200nm+ away even though my equipment code is /A. They seriously don't look or care. They just assume you have a GPS on board.
