Relative Humidity
moxiepilot
I can't find my reference offhand, but what is the formula for calculating RH?
I thought it was something like:
RH = ((Temp / Dewpoint) * 100 ) + 100
Anyone?
This is the formula I use:
Its really a curve-fit to a more-complicated relationship that considers specific heats and partial pressures and yer mama, so it works only with "air" (and not any other gasses).
I don't know how accurate an approximation you need, but the relationship between temperature, dewpoint, and relative humidity is non-linear, so you can't really know the relative humidity with just the ratio.
That said, I tried a couple of fits to the fit and found you can get a pretty darn close using:
%RH =100*[ (Tdew + 273.15)/(Tamb + 273.15) ] + (Tdew-Tamb)
(all temperatures in °C, valid between -20°C to +40°C for a dewpoint spread of not more than 25°C )
i didnt even think of it being non-linear, but now that you mention it it is obvious as to why...duh. thanks folks for the enlightenment and formulas.
