Unfortunately the answer to your question is probably too complex to address here. The use of SSRI medication is restricted to certain medications by the FAA, and even then allowed after evaluation by a special (HIMS) AME. You would likely need to have your treatment records and pharmacy records reviewed when they consider your application. If you are given a special issuance the FAA would likely review it again and issue a new special issuance if you wish to change the class of medical.
