Pfactor8
To somoneone who can explain things better than FAA knowledge books (which I usually find easy to understand, but not this time):
From the Pilot's Handbook of Aeronautical Knowledge (pg. 3-23): "'Twisting,' or variations in the geometric pitch of the blades, permits the propeller to operate with a relatively constant angle of attack along its length when in cruising flight." Then next sentence says that the blades are twisted to keep thrust equalized.
As I understand it the tips of the propeller are moving faster than the core and must have a lesser angle of attack in order to keep thrust equal along it's length. Shouldn't it say that the angle of attack (with the blade angle) must vary to keep thrust equal? What is the difference between angle of attack and blade angle? The relative wind making the difference here is that produced by the prop rotating. The relative wind component caused by the forward motion of the blade is constant for all sections of the blade so it can be ignored (right?). Level cruise flight also here.
I am going to get drunk now and agonize over this because I don't have a girlfriend.
