mrivc211
Today we went over many systems in the brasilia. Most of it is review but when time goes by, some of the minute details are forgotten very easily. Of the many systems we went over throughout this whole week, the prop really stuck out at me.
We saw a recreation made by Embraer of a brasilia going into a prop overspeed condition. It was just plain old scary to put it mildly. The pilots were on approach and doing 265knots descending thru 2500' with the GPS warnings going off. At 1000' AGL they leveled the airplane to drop the gear. (200 kias limitation) And at 203 KIAS they promptly dropped the gear and INSTANTLY the number two prop went into overspeed. I beleive I saw over 128% Np on the right side. The airspeed instantly dropped about 100 knots, and they lost 800' in about 9 seconds. The captain then tried to compensate quickly by adding power to the number one engine which only worsened the problem creating it to veer even more towards the right. At certain points both props were overspeeding. I'll see if I can get the video file of it somehow. It will definetly give you more respect for the airplane you are flying and take away the typical complacency we pilots tend to develop flying day in and day out without a hitch.
The outcome was pretty bad. They eventually could not keep control of the aircraft and the right wing hit a building flipping the plane over onto its back. You could hear both pilots scream just before impact.
Studying the systems over again, you tend to have a better overall idea of how things work. So when systems are explained to you in depth a second or third time, they make more sense. You find out what the weak points in the system is. Such as when pilots used to use the props as speed brakes above 200 knots which would create too much force on the prop, sending it into an overspeed condition, or tearing a drive shaft.
Careful out there guys!
