So . . . you're saying that you don't know how??FlyOrDie said:
C150J said:Thanks for the info -
JDE, thanks, but I remember an FAA guy showing me how to create a fictional arc and fly it, not a published arc.
J.
mtsu_av8er said:So . . . you're saying that you don't know how??It's pretty easy to point somebody in the direction of a manual everytime you don't know the answer . . .
FlyOrDie said:The best way to learn to use the Garmin is to read the manual and play with the sim, so I'd rather point someone in that direction than hold their hand as they turn knobs and press buttons.
mtsu_av8er said:Absolute nonsense. Why not just make Jetcareers into a site that says:
Read The Manual!
Read The Manual!
aloft said:but you could easily navigate an arc with a direct-to to the station and use the bearing and distance readouts.
EatSleepFly said:You mean like tuning in the VOR freq., centering the CDI with a from indication, watching the DME, and flying the arc the "old fasioned" (apparently) way?![]()
Are people getting that sloppy that they need the actual line to be depicted on a moving map so they can follow it?![]()
fish314 said:I suppose you could always put in a succession of points? xyz/360/10, xyz/001/10, xyz/002/10, ....![]()
