JSFirm Production Pilot Level 2\3
Status
Not open for further replies.
NewsBot
Administrator
Boeing Company Seattle, Washington:
Requisition Number: 1500012921en
Primary Location: Seattle, Washington, United States
Job: Pilot
Job Level: Entry Level
Shift: Day Job
Job Description
As a Production Pilot for BT&E Flight Operations, Commercial Production organization duties could include: After training has occurred you will be participating in production and acceptance test flights. Assists in the production acceptance process to validate configuration and contractual compliance. Identifies and documents flight deficiencies and coordinates resolution. Assists in delivery, ferry, support and functional test flights on production and non-production aircraft. This position will work into a Pilot-In-Command. Job requires FAA ATP or commercial certificate with the appropriate endorsements. This position will require domestic and/or international travel as needed to support the organization.
Position is the primary entry level position for all Boeing Commercial Production and Engineering/Experimental test pilots. This job entails operational flight validation of newly manufactured commercial airplanes. Job requires extreme schedule flexibility with frequent evening and weekend work. This position requires the ability to go on domestic and/or international travel assignments as needed. This position may require support of all commercial aircraft which could involve support of Seattle, WA, Everett, WA and South Carolina statement of work. The position may include the opportunity to fly any of the four new derivatives Boeing is currently developing. Military Test Pilot School graduate highly desired. Bachelor, Master or Doctorate of Science degree from an accredited course of study, in engineering, computer science, mathematics, physics or chemistry. ABET is the preferred, although not required, accreditation standard.
Qualifications
Level 2 - Degree and typical experience in engineering classification: Bachelor's and 2 or more years' experience or a Master's degree with experience. Bachelor, Master or Doctorate of Science degree from an accredited course of study, in engineering, computer science, mathematics, physics or chemistry. ABET is the preferred, although not required, accreditation standard.
Level 3 - Degree and typical experience in engineering classification: Bachelor's and 5 or more years' experience, Master's degree with 3 or more years' experience or PhD degree with experience. Bachelor, Master or Doctorate of Science degree from an accredited course of study, in engineering, computer science, mathematics, physics or chemistry. ABET is the preferred, although not required, accreditation standard.
This position must meet Export Control compliance requirements, therefore a “US Person” as defined by 22 C.F.R. § 120.15 is required.
Other Job Related Information
Experience Level: Entry Level
Job Type: Full-time
Travel: Yes, 10 % of the Time
Relocation Authorized?: Yes
Business Unit: Engineering Operations & Techn
Contingent Upon Program Award?: No
Union: No
Job Code: ADPFP2
Continue reading...
Status
