When I first got my instrument ticket, I was going into Idaho Falls on the ILS. Crossing the fix outbound, I was impressed that I had 180 knots groundspeed on the DME in a 120 knot airplane. I flew out for two minutes (6 miles) then turned on the 45 for 1 minute (about 3 miles) then another minute in the turn. Halfway through the turn I flipped the DME to miles and I was twelve miles out. The Grand Tetons are in that direction. Established inbound, the groundspeed went to 60 and I descended into the clouds to intercept altitude and started accumulating ice. I had about 9 minutes to fly in the ice before GS intercept. ATIS called for a 1000' ceiling and I broke out at 1000' AGL with 3" of rime all over the front of a Cardinal and no view out the windshield. Touched down with full power and a frozen pitot tube. Temperature on the ground was below freezing, so the Cardinal was on static display for several hours.
If I had to do it again, after seeing the high groundspeed, I would have started the procedure turn zero minutes after the fix, not one or two minutes. And once ice started accumulating, I would have gone to a localizer approach and bombed down to MDA, which was below the ceiling.
The purpose of going out for a minute or two is to give you time to get established and stable inbound.
Reference AIM 5-4-9: "However, the point at which the turn may be commenced and the type and rate of turn is left to the discretion of the pilot." 90/270, 45/180/45, Cuban Eights, wingovers are all okay. Stay within the prescribed distance, above the prescribed altitude and turn on the charted side of the course.
