FlyingNole said:"Ft. Lauderdale ground, Cessna XXXX at Quebec ramp information XXXX, with request"
(I like waiting for a response before I make my request,etc. At busy airports its more courtesy than anything)
after tower replies "go ahead" ....."Cessna XXXX would like to shoot a few practice approaches VFR, starting off with the ILS XXX"
One other thing to keep in mind is that filing IFR may constrain the controllers too much due to spacing and seperation issues. I have had conversations with some local ATC guys and their take was that they would rather have you VFR (conditions permitting) because they have a lot more flexibility in fitting you into the flow. Unless you want to practice holds and vectors for spacingroundout said:that won't work if you're out of instrument currency or if you're an instrument student practicing with a safety pilot who isn't instrument rated.
other than those two instances, i prefer to file IFR.
Well, if he means FLL, that's a Class C airport and you can probably expect that since Ground or CD gives you VFR departure instructions all the time that they'd bet the ones to tell that you want to do practice approaches.pkrgod said:So you can request the practice approaches with ground??
MidlifeFlyer said:When explaining, it's probably a good idea to keep the procedures for requesting practice approaches on a IFR clearance separate from the procedures for requesting practice approaches under VFR.
Even then theirs's a bit of variety. Jep, there are a bunch of places where you'd have to file an IFR flight plan through FSS or DUATS to get that IFR clearance for practice approaches and others where you would do what you describe.
It's sometimes funny to listen to a pilot call ground or clearance delivery and for the shortcut that is "normal" for them, only to get a reply that sounds like, "What? Are you nuts?"
How do you request a bunch of practice approaches?? Do you just radio approach, tell them where you are in relation to the VOR and request multiple practice approaches into an airport?
JEP said:The Class B area is is getting wider and the floor is dropping as well.
Let me once again offer "the view from the other side." (Hey.....that could be a new forumananoman said:Why not just file an IFR flight plan?
NJA_Capt said:Or maybe I'll just cancel and enter downwind from the crosswind![]()
pkrgod said:so whats the procedure for requesting approaches under VFR?
Just what you thought in your first post. If you are in the air, call the facility that handles approaches (Approach in some areas, Center in others) and, like everything else when dealing with ATC, tell them who you are, where, you are, and what you want.pkrgod said:so whats the procedure for requesting approaches under VFR?
