Post edit tag discussion (moved)
minitour
Ah, 400A edited his original post and added "(135/121/etc)", which was not there in the original post. He added it only after I quoted 91.175. You can see that if you look at the text that I quoted in my original reply.
So I will throw it back at you: :sitaware:
I don't see any "edit" text under his original post...the kind of label that shows up once you've edited your text.
:yar:
-mini
Re: ODPs
Yes, that is puzzling. But the alternative is that I deliberately removed the text in question from my quotation, for which it would be difficult to create a motivation.
BTW, I just edited this post, and there is no edit notation at the bottom. There appears to be a time limit under which you can edit without penalty.
Re: ODPs
3877 TT - 2155 ME - 1139 Turbine
3288 PIC - 442 Jet
135 Current
C208 (PC Jan '09 - FSI Jan '08)
CE525 (Initial May '09 FSI - 135.297(g))
Available for Contract Work
Failed recurrent vBulletin® Version 3.8.2
:D
(this post as been edited)
Re: ODPs
Interesting. I DID not know that.
-mini
Re: ODPs
I thought the edit post tag didn't get added in unless you actually put a reason in the box. I often times edit without adding a reason and it shows as normal.
Re: ODPs
I probably edit over half of my posts and this is how it works as far as I know.
Re: ODPs
Test. Uh...test your EGPWS prior to the first flight of the day. (edit 1 was 1 minute later)
...and run your annunciator or rotary test too!
...but don't accidentally blow the fire bottles while "testing" the valves like the boss-man did once
Of course, when you're the boss man, you can get away with that.
...maybe that IS how it works (the edit thing). I'll be damned.
...one more try. I guess that did it, but I didn't put anything in the reason box. Weird.
-mini
Re: ODPs
Like I said, I think it's time based. Within a certain amount of time it won't show that it's been edited unless you put a reason down. After that time it will show as having been edited.
I kind of wish it would ALWAYS show as edited. It can be confusing otherwise. Maybe I'll forward this to the boss as a suggestion.
Lemme check...
(boarding music)
Ahh, there it is! So what are you guys thinking a reasonable figure would be?
Actually, I think it ought to be either 0 or 1. People can be quoting the original post almost right away and it gets a tad confusing when things don't match up and there's no note that an edit has been made.
MHOO (My Humble Opinion Only)
I agree that *any* edit should be noted; I see no advantage to having a grace period. Not like we're saving trees or anything. ;)
Give me at least 5 minutes. I don't think I've made a post longer than one sentence without editing it as long as I've been here.
editing for comedic value
