The rule of thumb with most turbos is to use the same power settings as you would in any complex aircraft and then adjust as you feel you need to. Climb at the maximum MAP that will not overboost and full fine on the props. At 500' reduce MAP to 25" and RPM to 2500. Cruise depends on desired efficiency or speed but will range from 19" MAP to 23" MAP and 2100 RPM to 2350 RPM, follow the POH. Departure stalls should be practiced at at least 65% power, though anything up to full power without overboosting is appropriate, 30"MAP and full fine on the props works well. Approach to landing stalls should be practiced at 15" to 16" MAP and full fine on the props for drag, gear down and whatever flap setting you prefer. Be careful about not overboosting the engines on recovery from stalls and slow flight. As far as instrument approaches are concerned, lower the gear, deploy 10 degrees of flaps, and pitch for 90 knots while reducing MAP in increments, when you get a 500' per minute descent rate you have found the power setting for ILS approaches, when you get 700' per minute you've found the power setting for nonprecision approaches. Downwind in the pattern will be roughly 20" MAP and 2300 RPM, if you get 100 knots in level flight with the gear down, you're good, if not, adjust the MAP.
One long familiarization flight by yourself, or with the student, while taking notes, should be enough to find the right numbers, it's also a great drill for practicing precise control of the aircraft while establishing constant speed/rate climbs and descents. The best way to fly any light aircraft is by sight, sound, and feel, the numbers are only a starting point.
I think the only reason some of us get our hackles up, is that it is a CFI's job to learn how an aircraft behaves before we take students up and teach them what to do. The FAA's intent behind the 5 hours of PIC time in multiengine aircraft is for the instructor to learn the aircraft. As professional flight instructors we are hired by the student as experts. When I fly a new make/model, I either take the aircraft up by myself and try all of the required manuevers, or I admit to the student my lack of first hand knowledge, and if they are ok with that, we go up together and experiment. In most cases, the insurance requires that I get the hours in the aircraft before I instruct, so that means the owner has to let me fly the airplane if he wants me to be his instructor.
