PICKING UP THE G1000
Goonie
Never say die
IM A SKYMATES INSTRUCTOR AND IM GOING TO INDEPENDENCE KANSAS TO PICK UP OUR NEW 182T WITH THE G1000 I WAS WONDERING IF ANYONE HAS FLOWN THEM AND WHAT THEY THINK. I WAS ALSO WONDERING IF ANYONE HAS GONE TO CESSNA TO PICK UP A NEW PLANE. DO YOU HAVE ANY SUGGESTIONS OF WHAT I SHOULD CHECK OUT WHILE IM THERE.
Nothing about what to check out, but I've got about 60 hrs in a 182 with the G1000. If you can work a GNS430, then you've already got a big one-up on the G1000. It's like a lil CRJ, and affords great SA. You'll see what I'm talking about when you go out there. Do some studying though, there's a LOT of systems stuff to know with all the boxes. Enjoy!
DUDE, WE ALL HAVE NEW BATTERIES IN OUR HEARING AIDS. No need to SHOUT.
Steps to change the battery in YOUR hearing aid:
1. Find the 'A' key
2. Look to the left of the 'A' key.
3. No, your other left.
4. Notice the key that says 'Caps Lock'.
5. Place finger on the key that says 'Caps Lock'.
6. Apply pressure to finger so as to depress the 'Caps Lock' key.
I haven't flown one but I would try and learn as much as possible while at Cessna. If a Cessna pick up is like a Cirrus pick up, they'll take you around the pattern and show you the ropes and the tricky things about the plane. Take advantage of that and ask a bunch of questions.
OKAY SORRY ABOUT THE CAPS how did you like the Cirrus I have about 5 hours in one and was real impressed.
Unfortunately I haven't got to fly in it yet. It's a friend of mine's, so the info on the pick up is secondhand, but he seems to like it a lot.
I made the pickup in Independence last August...I will try to get back on here Tuesday evening and give some details for you. I would right now, but it is late and i'm heading off for a couple of days of snowboarding tomorrow
ps Independence is rather boring. Ok, so its really boring!
Ask them if they can get you a beta version of the G1000 simulator. It will help. As stated above, if you know about the 430 you have a pretty good head start. Even if you don't, after about an hour or so you're really going to love the G1000. There is a free 430 simulator you can download to give you a few tips, if you can work that you'll have no problems with procedures on the G1000.
I flight school has three airplanes with the G1000, and teaches a G1000 transition course. I have around 100 hours of G1000 time, with about 30 of that in a C182.
The Cessna system has some quirks, As of right now, you cannot use the audio portion of the marker beacons, due to an issue with the volume that they are set at and the chance it could cause you to miss a radio call. Also do not forget about the standby battery switch. It is very easy for someone that is not familiar with the system to leave it on which will drain the standby battery. It has a fuel totalizer that works great to give you information about your fuel range which we have found to be accurate within a tenth of a gallon, but if you do not take on full fuel, there is no way to tell the system how much fuel you have, and could cause problems. The Diamond software does not have these problems as you can use the marker beacons, you can tell the system you do not have full fuel, and the standby system functions differently.
As to flying the G1000, I was comfortable with the glass display after one flight, but it took me a couple more flights to be completly comfortable with the system. The GPS functions exactly like a Garmin 430 or 530, so if you know how to operate those GPS systems it will help alot. A couple things to remember are that an airspeed tape moves the opposite direction of the needle on an airspeed indicator. This is the thing that seems to give my students the most trouble on the first flight, and that the altitude bug is for reference only it does not tie into the KAP140 autopilot. It is a great system, and you will really enjoy flying with it. I would much rather have an airplane with a glass cockpit in IMC now that I am comfortable with it and I have flown into low IFR with both. Let me know if you have anymore questions.
SUSpilot,
thanks for all the info I dont have any questions yet but I still dont go to training till tommarow so I will let you know if I need any more help. One thing I was wonderinig is it to bright on night flights Im sure it has a dimming feature but I like a real dark cockpit at night.
It has an automatic dimming feature like the 430 and 530. It is also tied into a rehostat that allows you to adjust the brightness how ever you like.
I was the first guy checked out on the G1000 C182T at my flight school. Our school is a Cirrus training center, which means that there are a lot of folks who are big fans of the Avidyne and SR20 product. No doubt about it, the Cirrus with the 'glass' cockpit is a great plane, but I'd still take the 182T with the G1000 as my primary plane. I LOVE this combo...
However,
Wishes for the G1000:
1) Auto-pilot integration.
2) A simulator like the 430 and 530 sim currently available. It's pretty expensive to simply start the engine on the 182.
3) A connection between the fuel totalizer and what is actually in the tanks. I know I can reset it, but it sure would be nice to have the fuel level automatically 'sensed' from the amount that is actually in the tanks.
Looks like I missed giving info for the original poster - sorry the snow was too good to come back home! Have fun in IDP!!
The G1000 is truly fantastic - anyone have anymore inside as to when the PC sim is going to be availabe? I picked up the C182 in August 2004 and used the 'beta' version then. It seemed to run pretty well then! I wonder what is taking so long?
Our school has made a GPU to use for now until we get our hands on the PC sim. Works really well, just make sure you contact your mx shop to help you if you are unfamiliar with setting those up. Sure beats making your students learn to push the buttons while the engine is running!
After giving many checkouts, I can for sure say those with Garmin experience do better than those with no experience. Also the 'computer generation' seems to pick things up a little quicker as well. No, I'm not picking on any of you 'old-timers'!
Also, in general anyone with any amount of GPS, autopilot experience usually show a faster learning curve.
Cheers!
-Nick
Im in IDP right now at the Appletree inn not so bad I went to some bar called Turbos about the best to get here I start my G1000 training tomarrow so Ill keep you posted about sims on the system. Sorry about the typos but ive had 5 yagermiester shots
