You can still fly more than 34/7, 120/month, 1200/hrs a year though. or 8 without a rest period, by having the phrase "This flight is operated under Part 91." added onto your dispatch release. then at that point no duty time/flight time limits apply. Then the next time, you are assigned a flight under "Part 121 operated under Part 135 duty time limits" then the rules apply again within the 24 hour period (the time you flew under Part 91 then counts under Part 135 for the 34/7, 120/month, 1200/year.)
Got a legal interpretation for that? AFAIK, the 34/7, 120/mo and 1200/year is all commercial flying just like the 500/800/1400 for on demand ops. That includes part 91 commercial flying, such as empty repositioning legs for an air carrier, part 91 flying while being compensated (think corporate), flight instruction, banner towing, jumpers, etc. I'd be interested to read any interpretation from the chief legal counsel (not a FSDO...they don't have that authority) saying that the Part 91 flights do not count. That could be very,
very important for me in the (hopefully) near future, so I'd like to see the interpretation.
--Break--
To expand on what I said earlier for the OP...
The flight time limits can be over-flown under the on demand regs, provided it was due to circumstances beyond the control of the certificate holder. Of course, that being the case you will receive compensatory rest.
Note that there is nowhere in the regulations does it allow for you to be at a point where you can look back 24 hours and
not see 10 consecutive hours of rest.
Now, if you do either, it had better be due to
circumstances beyond the control of the certificate holder. Let's examine that one a little closer.
"circumstances beyond the control of the certificate holder"
What that means:
- ATC delay once out of the blocks adding to your flight time.
- Weather deviations adding to your flight time.
- Holding, flow, spacing issues adding to your flight time.
- Any of these factors causing you to land and duty-off at a point in time when you look back and can no longer see 10 hours of consecutive rest in a 24 hour period.
What that does
not mean:
- Pax show up 4 hours late and you know if you leave now you will go over your "duty limits".
- Pax show up 4 hours late and you know that because of the storm that moved through, you will be routed from BCT over MSY to try to get up to PIT, taking you over your flight time limits. This is not a reroute once in the air...this is either your clearance before you left the blocks or what you flight planned. Either way, you're done.
- Freight shows up 45 minutes late and ATC gives you an EDCT time, gate hold, etc. Under a gate hold, you probably won't be given a taxi...if you are, then you have left the blocks and you have already started the flight. Same with an EDCT. If you have left the blocks, you have started your flight. Once you start your flight legally (you know if you leave now that when you land you'll still be legal), you are legal to finish it.
- That is where the "legal to start, legal to finish" comes in. It does not mean that if you are scheduled ABC-DEF (2.0 flight) at 0100 (after a 0000 show) and return DEF-ACB (2.0 flight) with a scheduled arrival at 1330 (with a 30 minute post flight) that you are legal to finish the DEF-ABC leg if your pax show up at 1245. At that point, you would not be legal to finish the flight if you started it.
- Starting the engine(s) and taxiing are not circumstances beyond the control of the certificate holder. You can control pressing the start button. You can't control getting a hold or being stuck in the pad for 3 hours when you expected to just get straight out. Now, if you try to be clever and beat the system and taxi out...when you return to the ramp for more fuel, you've just blocked back in. You need to call a new crew.
Try to keep in mind that if your company tries to pull any crap with you (and some will, some will not) and you do it and a fed finds out...you will be violated, the company will probably have some paperwork to do and you will be on the streets with a violation on your file. Yes, you'll probably get pressure to do something illegal (believe me, I do at least twice a rotation at this bottom feeder). You need to be able to say "no" when it's appropriate, have a reason (know the regs, rest and flight rules) and stick to it.
It's better to be fired without the violation than fired and violated. I'd rather explain being let go because I refused to stay on duty for 20 hours than explain why I was violated for being on duty for 20 hours...
Best of luck!
-mini
