Well, took the test today. I took the floating E's test, and thought it went well. Had 20/20 vision on the charts, and then the dreaded words-"now lets check your color vision". If you don't know what it is, it shows 2 rows of 4 boxes, and in each box is a different color-kinda like the Ishihara plates-and the E is facing a different direction in each one. Flew through the first 4-no problem, then got the next 1 and started having problems with the last 3.
The nurse assured me I only need to get 6 out of 8, so I got the next one right and flipped the last two-so I got the 6 I needed. I was extremely happy!! Well, that lasted for about 5 minutes-I went in to see the doc, and he said-"I see you had a problem with the color? Let's get out the color plates and see how bad it is". I panicked...that is why I went to him-I knew he had the alternate test I could pass. Sure enough, I can't see hardly any of the plates. He then said the dreaded words-I am going to have to put "Not valid for night flight or by color signal".
I couldn't believe what I was hearing-I thought I was ok with the first test...then this happened.
How can I pass one test, then he re-evaluates me and gives me the restriction. Is that right?? Can he do that?
Of course he tells me, now you can contact FSDO and schedule a light gun test and get that taken care of. But, from what I heard you don't want to do that because if you mess up, you get the permenant restriction. Any ideas or suggestions would be GREATLY appreciated!!!
