So, I'm colorblind and am fairly confident that I can pass the OCVT.
Well, that was until I just found out that the requirements are more involved for 1st and 2nd class medicals than the 3rd class.
According to someone on Yahoo Answers this is what you have to do:
First, do I need to already have a pilots license to take this test (because I don't) or could I fly as a passenger?
Second, is there a way for me to study the different lights other than going to an airport at night?
The FAA has added a operational color vision test to the light gun test
If you cannot pass one of the alternate tests, you have another option that requires taking an operational color vision test with an FAA aviation safety inspector through the local flight standards district office (FSDO). The information describing the tests is found in FAA Order 8900.1, FSIMS, Volume 5, Chapter 8, Sections 5-1523.F, 5-1526.E.6, and 5-1527 F
This test has two components:
For third class medicals:
(a) A signal light test administered at an airport air traffic control tower; and
(b) A practical test in which you must read and correctly identify colors on aeronautical charts
For first or second class medicals:
(a) Successful completion of an operational color vision test (OCVT) described above; and
(b) A color vision medical flight test (MFT). This is an actual flight test and requires the following:
(1) You must read and correctly interpret in a timely manner aviation instruments or displays, particularly those with colored limitation marks, and colored instrument panel lights, especially marker beacon lights, warning or caution lights, weather displays, etc.
(2) You must recognize terrain and obstructions in a timely manner; select several emergency landing fields, preferably under marginal conditions, and describe the surface (for example, sod, stubble, plowed field, presence of terrain roll or pitch, if any), and also describe how the conclusions were determined, and identify obstructions such as ditches, fences, terraces, low spots, rocks, stumps, and, in particular, any gray, tan, or brown objects in green fields.
(3) You must visually identify in a timely manner the location, color, and significance of aeronautical lights. To minimize the effect of memorizing the color of a light associated with a particular light system, the aviation safety inspector should make every effort to not use the light system name during the flight, but rather to ask you to identify a light color and the significance of as many of the following lights as possible:
(a). Colored lights of other aircraft in the vicinity;
(b). Runway approach lights, including both the approach light system (ALS) and visual glideslope indicators;
(c). Runway edge light system;
(d). Runway end identifier lights;
(e). In-runway lighting (runway centerline [CL] lights, touchdown zone [TDZ] lights, taxiway lead-off lights, and land and hold short lights);
(f). Airport boundary lights;
(g).Taxiway lights (edge lights, CL lights, clearance bar lights, runway guard lights, and stop bar lights;
(h).Red warning lights on television towers, high buildings, stacks, etc.;
(i). Airport beacon lights.
If you pass the operational color vision test (OCVT) and the color vision medical flight test, the inspector will issue a letter of evidence that’s valid for all classes and a medical certificate with no limitation or comment regarding color vision.
