Vector4Food
This job would be easier without all the airplanes
There has been some local debate here, amongst controllers, friendly of course, as to what from the airlines and pilots point of view is the most efficient method from your side for in-trail spacing (Not approach, enroute airspace)
Scenario would be something like, 200NM to establish in-trail spacing, regardless of altitude, a common every-day occurance at many enroute centres around the world, including mine. As a controller, usually the "easiest" method is establishing a Mach restriction (speed up/slow down) to get the spacing you need, the faster method time wise, is an off-course vector (50-90 deg) until the spacing is established.
From a pilots point of view of economy/personal preference, what would be preferred? A mach change of .02-.03 +/- for 30-45 minutes or the vector as above for 2-3 minutes.
Now bottom line is, as ATC we're going to do what works best given the current situation but there are times when either would work just as well, and the discussion as to what actually IS more efficient.
Any comments appreciated.
