linked website said:The MDA of a circling approach gives an obstacle clearance of 300'
I believe its 300 due to
75 feet altimeter error
100 feet pilot deviation
125 transponder pres alt error
thats worst case scenario if everything was on the negative side
I should know this. . .but. . .
http://whitts.alioth.net/Pageg35 All About Mimimums.htm
This website says it provides 300' obstruction clearence within the radius.
No source listed.
Unless you read that somewhere, I suspect you're trying to ascribe too much logic to an arbitrarily derived figure. The transponder figure alone is irrelevant, since it plays no role in obstacle clearance. While the 75 feet altimeter error is used in pilot literature as a gauge of altimeter system reliability, I've never seen that figure used in TERPS related documentation. And to allow only a 100 feet of pilot-induced error before the pilot hits something would be very alarming.
But, as others said, 300 feet is the correct number.
I kinda just made that up as to why it might be 300
So I figured.However, you probably convinced some readers, since your numbers added up.
Does it change for each category? I'm thinking no...
Thanks for your help guys. I knew it was 300, but I couldn't put my finger on a source!
I mentioned transponder because ya know when you're low the controller goes 'low alt alert, check alt immediately etc etc'
I've never had a controller say this when I'm inside the FAF or have all ready commenced the circle.
Is that normal?? Are they even watching your mode C hit when you're circling??
No, because you're on a segment of an already established approach.
Low altitude alerts will occur (traditionally) in areas where an MVA is being penetrated by a pilot that failed to maintain his/her latest altitude assignment that was say AT the MVA, or slightly above it.
