FOD said:I have always been under the impression that the oxygen requirements above 12,500 ("more then 30 minutes duration") is cumulative, but havent see it anywhere. Someone wanna clear this up for me?
§ 91.211 Supplemental oxygen.
(a) General. No person may operate a civil aircraft of U.S. registry—
(1) At cabin pressure altitudes above 12,500 feet (MSL) up to and including 14,000 feet (MSL) unless the required minimum flight crew is provided with and uses supplemental oxygen for that part of the flight at those altitudes that is of more than 30 minutes duration;
Wow now that is a good hangar question. I'm going to spread that one around a few places.caliginousface said:when i was going for my inst. ticket my instructor asked me this question. i said you could dip below 12500 for a little and come back up, and you'd get a brand new set of minutes, she said yep. (but maybe it is cumulative?) is it good practice? nah, you're risking too much there, like FOD said.
moxiepilot said:When you think about it that way, the reason you get 30 more minutes duration is that theoretically you have returned to the level of the atmosphere where the partial pressure is significant enough to return your oxygen supply and distribution to normal levels. Would I dip below 125 for a minute and go back up? No, but if I came down to 5k for 30 minutes I might consider going back up.
