CollinsProLine
According to the latest findings, once the Pinnacle pilots put themselves in a bad situation and stalled both engines, they had no chance of restart because the engines locked up due to "engine core lock". Any thoughts?
Pinnacle Probe Unveils Training, Engine Flaws
Aviation Week & Space Technology
06/20/2005, page 49
Frances Fiorino
Washington
NTSB findings show that the crew attempted restarts according to manufacturer and company guidelines. However, the attempts were unsuccessful.
"If just one of the two stalled engines had restarted, this accident would never have occurred," said ALPA Chairman of Safety Terry McVenes. "The crew followed proper procedures. . . .But both engines failed to start because they had suffered "core lock--a risk previously known only to engine and aircraft manufacturers."
The engine core lock phenomenon is not well-known or understood throughout industry. The term refers to the seizure of the engine's core, or inner spool, by differential cooling that causes parts to bind.
Bombardier said every "prone" aircraft (CL300, CL604, CRJ200, DHC-08) is tested prior to delivery. During initial aircraft certification, engines are forced to 0% core speed and the aircraft is accelerated to confirm that engines will not lock up and can be windmill-restarted. The manufacturer said the CF34-3 engine series has two areas suspected of causing core lock-up: the outer balance piston seal and inter-stage seal. The latter was found to be a contributor and a design change was implemented, reducing the lock-up phenomenon to 1.5%.
06/20/2005, page 49
Frances Fiorino
Washington
