Care to advise me? Because a google search bought up so many ADs for the beleaguered jet I couldn't find the exact AD.
But I guess thats what you get when you convert a private jet holding 6-8 into a 121 jet cramming 50 and their bags into the same airframe.
sigh
I guess. I'm going to simplify it because I don't want to type up a book about the flap AD, it comes up as the first option if you
google it. Scroll down to "Requirements of AD 2007-17-07, Amendment 39-15165: Actions and Compliance".
Flap AD has a few parts...
First there is a flap extended diversion, which has two options. Option 1 restricts the pilots from lowering the flaps unless certain weather conditions exist for a precision and non-precision approach. Option 2, which is hardly ever planned (I did it once in training), includes using a fuel factor of 3.2 for the alternate burn. There is also an altitude restriction when selecting an alternate, you can't go above 15,000 so you can't have terrain above that (think Denver, can't go west).
Then there is the part that applies to take off alternates. You have to have at least 1,000lbs when arriving at the takeoff alternate with flaps in the takeoff position. There is a way of checking/calculating that with a fuel factor of 1.8, and you don't always end up needing to add more fuel. Same 15,000 ft altitude restriction exists there.
Then there is dispatch following a flap fail event, which has a bunch of requirements that must be met in order to operate. This includes operating the flaps a certain amount of times, checks for thrust reversers, spoilers etc, and then the LDA on a usable runway at the destination and alternate needs to be at least equal to the flaps 0 landing distance. That part is an either or, it can be either the destination or alternate but OO is more conservative and requires both be met, so I guess that ties in perfectly with the topic of your thread.
I took the bait, didn't I?
