If neither of you are night current, neither of you can act as PIC with the other on the plane.
Sent from my DROID RAZR using Tapatalk 2
As long as your acting as an instructor, I see nothing wrong with it. (stole this from one of Rframe's post).
61.57(b)
(b) Night takeoff and landing experience. (1) Except as provided in paragraph (e) of this section, no person may act as pilot in command of an aircraft carrying passengers
There are a couple letter of interpretations from the FAA on this. Here's a snippet from one from Rebecca MacPherson (Assistant Chief Counsel).
We agree that, for purposes of section 61.57(b), an authorized instructor providing instruction in an aircraft is not considered a passenger with respect to the person receiving instruction, even where the person receiving the instruction is acting as PIC. (The instructor must be current, qualified to instruct, and hold a category, class and type rating in the aircraft, if a class and type rating is required.) The instructor is not a passenger because he is present specifically to train the person receiving instruction. Neither is the person receiving instruction a passenger with respect to the instructor. This training may take place, even though neither pilot has met the 61.57(b) requirements.
What if the airplane requires a type rating and is an airplane in which the ATP is typed? Can the ATP give the CFI dual in that airplane at night if the ATP isn't night current?
OHHHHH DOUBLE SNAP!
I haven't had nearly enough coffee yet to try to figure that one out.What if the airplane requires a type rating and is an airplane in which the ATP is typed? Can the ATP give the CFI dual in that airplane at night if the ATP isn't night current?
OHHHHH DOUBLE SNAP!
Figures that the FAA would require a safety pilot to hold a medical...
Now it is entirely possible that I may me missing something, somewhere..... I just want to be sure.
Safety pilots are required to hold a medical just as SIC's are also required to hold a medical.
61.3(c)(1)
(c)Medical certificate. (1) A person may serve as a required pilot flight crewmember of an aircraft only if that person holds the appropriate medical certificate issued under part 67 of this chapter, or other documentation acceptable to the FAA, that is in that person's physical possession or readily accessible in the aircraft. Paragraph (c)(2) of this section provides certain exceptions to the requirement to hold a medical certificate.
...because the reg (quoted above) that requires a medical only requires one when acting as a required crewmember.Ahhh, there it is! Thanks!
Based on the interpretation that a safety pilot must have a current medical. I wonder what the FAA's reasoning is behind a CFI being able to provide instruction with out one? I understand that, as long as the CFI is not acting as PIC or a required crew member.
A CFI who is training a student pilot is required to have a medical because the CFI must act as PIC. Same for a CFI that is giving training to a pilot under the hood (required crewmember). But not when giving, for example, a FR to a current private pilot who is acting as PIC for the flight.
Permitting current, certificated pilots who are capable of and in fact acting as PIC to benefit from the knowledge and experience of older CFIs. A bit of failing eyesight would not make a CFI who has spent 50 years flying in the mountains unqualified to provide mountain instruction. And the current certificated pilot receiving that instruction is in a good position to make the determination if he wants that instruction.I understand the regulatory reason why. What I don't understand is HOW the FAA came to the conclusion that it would be OK for a CFI to provide any kind of dual (as long as they're not acting PIC or as a required crew member) without out a medical? What's reasoning behind the exception?
What makes you say that? The FAA doesn't think it's OK at all. A CFI who hops in an airplane with a pilot without a current FR is required to have a medical.Why does the FAA think it's ok to allow a CFI with out a medical to hop in a plane with a pilot who could have possibly not flown in 24 calendar months to give a flight review?
Read the reg again. The CFI rule is not carte blanche for CFIs without medicals to give "any kind of dual" - only that instruction that does not require a CFI to act as PIC or as a required pilot crewmember. That excludes a whole bunch of training.
