Sure! How do you think aerobatic airplanes stay aloft during inverted flight?
How is AOA measured?
The Zero lift angle of attack is -4 Degrees .. so basically you always have a negative angle of attack.
Depends on the airfoil, of course. The zero lift AOA is zero on a symmetrical airfoil.
I have been watching to see if there was going to be some elaboration of this, as it should be clear that the particular AoA in question would only pertain to a particular airfoil section. The above post appears to imply that this is a number that can be used for any asymmetric airfoil.
