My Long (or not so long) cross country
GUNIT
After trying to sit down and write this out twice but being stopped by having to go out and snowblow the whole driveway, here goes:
I had been trying to get in my long solo x-c for a few months now but had been weathered each time. Its getting close to my 17th birthday (the 21st) so I want to get this out of the way so I can do my test prep. I had planned a flight from KBED-KLCI-KGFL-KBED, easily exceeding the 150nm minimum. I took the day off of school (the 8th) to do this flight. I got up at 5:30 am to do all my winds aloft, fuel, and time calculations. I set out for the airport at 8 am so I could reach it by 9 to get my plan checked over by a CFI. What normally is a 15 minute drive turned into an hour thanks to an accident. So I reach the airport and it takes about 30 minutes to check my plan and all looks good. The weather is perfect. So I head out into the cold, take the wing covers off, and do a thorough preflight of the Katana (DA20-A1). The line guys preheated the engine and topped off the tank. I started her up, called ground and I was off. Take off was uneventful as was the whole flight up to Laconia. (I totally recommend LCI, its got a great approach path right over Lake Winnepasauke...sp?) I got topped off again at Laconia and went right off to Glens Falls. I climbed up to 6500 and made it past my first two checkpoints. Just then I noticed the Generator Warning light flicking on and off. However, everything else was reading normal. I figure oh well, must be a faulty wire. A few minutes later i went to scan engine gauges and noticed the ammeter showing a slight discharge. I decided that it was something I was going to keep a very close eye on but keep going. Not more than 20 seconds later the DG carded (little card sticks out to indicate it is inop/failed) and the ammeter started to show a greater discharge. By now the generator warning light was on full and I realized that I had a generator failure. Now you could perceivably continue the flight, but I was going to be flying over 4000 foot mountains and I decided I didn't want have only an altimeter, airspeed indicator and VSI. Not to mention that I also would have lost the radios, flaps and eletric trim once the batter wore out (30 mins). Thankfully Lebanon (KLEB, a small class D) was about 5nm away and I informed Boston Center of our problem and, since our DG was gone and I turned off the GPS, I asked for a vector to Lebanon. Turned about 10 degrees and had it in sight. He informed Tower of what was happening and switched me over. I got the flaps out early to lose some altitude and also so that I still had battery power to get them out. Tower cleared me and I landed fine. Got progressive to the FBO (Signal), parked, and chocked her. I called my instructor and the Maintenance back at the club and they suggested to have the maintenance tech at Signal have a look. So I went and got him and he gave it a look but didn't have any experience with Diamonds thus he couldn't help me (but he didnt' charge me anything :)) I called back the club and they said they would send 2 people up (I would have to fly back with someone else because by the time they arrived it woudl be close to sunset). So I waited at Signal for about 2 hours and finally the maintenance guys arrived in an Archer III and replaced the Generator on the spot. One of them took the Katana home and I got a ride in the Archer. I have to say the Archer was pretty rad. I can't wait to get checked out on the warrior once I get my ticket. Anyways, finally got back to Bedford and ended my journey for today. So much for my long x-c, but I did gain some valuable experience.
Good for you....nice job at :sitaware: !!! By the way...I'm 19, just got my ticket, and learned in a cherokee 140, and cessna 172N...now I'm starting to fly the archer, and warrior...very nice planes, and hoping to get into a 172RG and SP....hows the Katana fly?...Never been in one.
Good decisions.
I've flown up to Lebanon and Laconia before. It can't be a lot of fun to have an emergency with all those mountains nearby.
Yeah I figure it might make for a decent college essay :P
The katana is a fun little plane to fly. Taxiing is an aquired skill with it, but once in the air she's real responsive and the stick is pretty cool to fly with. If you're used to a piper or cessna, the seats aren't so comfy. However, the visibility is fantastic. Definitely worth checking out.
