Bandit_Driver
Gold Member
Can someone please educate me on the use of the Multi-quote button....I can't seem to get it to work.
Thanks
Thanks
Thanks
Haha. Works pretty good.I have also tried to get it to work several times in the past few years only to give up after following someone's instructions precisely and having it not work.
Haha. Works pretty good.![]()
see what i did was hit the ""+ icon for the first two quotes and then hit the quote button for the last quote i wanted to refer to... and it works just fine!No, seriously...
To do a multi quote, there is a button right next to the "Quote" button on the bottom right of the poster's post. It's a "+" sign. Press the + once and in a second or two, it will turn red and be a "-" sign. Now, all you have to do is press as many of these as you want, and it'll have all of those quotes in the reply function.
So, just in case I confused you, go to a thread, hit all the "+" signs you want in the multi quote, and in the order you want them to appear, and they will turn red and become "-" signs. Press the "Post Reply" button and you can now respond to all the quotes you just put in.
I hope this helps.
Thanks
No, seriously...
I hope this helps.
and like magic,,,,,,![]()
The quotes get arranged depending on the order that you click the "Multi-Quote" buttons, too.Can someone please educate me on the use of the Multi-quote button....I can't seem to get it to work.
Thanks
Thanks
Finally...I have also tried to get it to work several times in the past few years only to give up after following someone's instructions precisely and having it not work.
Yes, as far as I know, you have to pick the quote apart manually. I don't see how the software could possibly know which section of a quote you would want...so have fun with it.Thanks Stone Cold.
It turns out I was doing it correctly every time I'd tried on any vBulletin forum.
I just thought it gave the ability to quote multiple separate paragraphs within the same post. Alas, it does NOT give a way to do this at all, just quotes from different posts in the same thread.
So every time I see someone picking apart one post by a user in multiple quotes they are breaking it up manually themselves?
Less useful than I thought it would be but better than nothing.
And that is why I put this:The quotes get arranged depending on the order that you click the "Multi-Quote" buttons, too.
in my instructions!!hit all the "+" signs you want in the multi quote, and in the order you want them to appear
There is one aviation forum that I have had an account on for 8 years and it does allow it BUT it is HTML and I think it takes them quite a bit of time to make changes to it, whereas this vBulletin format makes it simple for those in charge (which is obviously desirable).Yes, as far as I know, you have to pick the quote apart manually. I don't see how the software could possibly know which section of a quote you would want...so have fun with it.
And that is why I put this:in my instructions!!![]()
Wow - I can Multi quote now!There is one aviation forum that I have had an account on for 8 years and it does allow it BUT it is HTML and I think it takes them quite a bit of time to make changes to it, whereas this vBulletin format makes it simple for those in charge (which is obviously desirable).
And again.Thanks Stone Cold.
And even moreFinally...
Thanks for the help....
I feel like a big boy now!The quotes get arranged depending on the order that you click the "Multi-Quote" buttons, too.
Oops.And that is why I put this:... in my instructions!!![]()
