Somebody do this one for me while you're at it...
KRIV 081955Z 30009KT 10SM CLR 32/10 A2995 RMK AO2A SLP136 T03150102
KRIV 0820/0920 30009KT 9999 FEW250 QNH2990INS
TEMPO 0822/0902 30012G18KT
BECMG 0902/0903 30006KT 9999 FEW250 QNH2988INS
BECMG 0918/0919 30009KT 9999 SKC QNH2994INS T33/0821Z T13/0912Z
Riverside (March? AFB) Eight Day, 1955 zulu time Wind 300 @ 9 kts, visibility 10 statute miles (or greater), sky clear below 12,000 ft, temperature thirty two degrees Celsius, dew point ten degrees Celsius, Altimeter 29.95 in hg, remarks automated weather equipment with precipitation discrimination (AO2A), sea lever pressure 101.36 hPa (I think), temperature at observation 31.5 degrees, dew point 10.2 degrees.
Forecasted weather at RIV between the 8th at 2000z to the 9th at 2000z
At 2000z on the 8th until the 9th at 0200z, winds forecast 300 degrees at 9kt, visability greater that 10km, few clouds at 25,000 ft, minimum altimeter setting 29.90 in hg.
At least half of the time between the 8th at 2200z and the 9th at 0200z, the winds will be from 300 degrees at 12kts, gusting to 18kts.
The weather will gradually become (between 0200z and 0300z on the 9th) the winds will become 300 degrees at 6kts, visiblity greater than 10km, few clouds at 25,000 ft, minimum altimeter setting 29.88 in hg.
The weather will gradually become (between 1800z and 1900z on the 9th) the winds will become 300 degrees at 9kts, visiblity greather than 10km, sky clear, minimun altimeter setting 29.94 in hg, the forecast high temperature is 33 degrees at 2100z on the 8th, the forecast low temperature is 13 degrees at 1200z on the 9th.
