more than i haveJepp
PTS
Oral
Paul Craig
Multi Engine Pilot Flight Maneuvers
Transition To Twins
THE COMPLETE MULTI-ENGINE PILOT
Am I missing anything beside a shot of Captain Morgen and Jack Daniels?
Jepp
PTS
Oral
Paul Craig
Transition To Twins
We have books for the mei?
I just referenced the Jepp Multi Engine book, AFH, PHAK, and some odds and ends.
I was given a 20 some page packet with everything from aerodynamics to Vmc demo and configuration for Vmc certification, I think it was sufficient . . . Hmmm I wonder if this is why so many people make crators in twins when they should be safer![]()
I understand it might be a rhetorical question but yeah, alot of people do not understand the relationship of stall speed and VMC.
§ 23.149 Minimum control speed.
(a) VMC is the calibrated airspeed at which, when the critical engine is suddenly made inoperative, it is possible to maintain control of the airplane with that engine still inoperative, and thereafter maintain straight flight at the same speed with an angle of bank of not more than 5 degrees. The method used to simulate critical engine failure must represent the most critical mode of powerplant failure expected in service with respect to controllability.
(b) VMC for takeoff must not exceed 1.2 VS1, where VS1 is determined at the maximum takeoff weight. VMC must be determined with the most unfavorable weight and center of gravity position and with the airplane airborne and the ground effect negligible, for the takeoff configuration(s) with -
(1) Maximum available takeoff power initially on each engine;
(2) The airplane trimmed for takeoff;
(3) Flaps in the takeoff position(s);
(4) Landing gear retracted; and
(5) All propeller controls in the recommended takeoff position throughout.
there is a chart in the AFH about the relationship. it isn't that complicated.I am not sure that I see the relationship either to be honest. For instance an aft CG raises Vmc because there is less of an arm for rudder authority (usually the limiting factor at least in small twins) yet aft CG reduces stall speed. Flaps down/up can change Vmc, sometimes lower, sometimes higher but always lowers stall speed.
Other than that I think they go fairly hand and hand? But I would be careful trying to relate Vmc to stall speed, anyone else have some input here? I am not an MEI, but I would love to know what you guys teach and why. Thanks
Here is the regulation on Vmc. Thanks tgray I stole this from one of your other posts.
Physics does not require a relationship between Vmc and Vs; if you had an airplane that would not stall, you would still have a Vmc.
However, in most light twins, it so happens that Vmc is only slightly above Vs, bringing about a real possibility of a single-engine stall.
I am not quite sure I am following you. Are you saying there is a relationship or are you saying there isn't because Vmc would exist even if Vs did not?
Vmc depends on the relative strength of the yawing moment produced by the thrust of an engine versus that of the vertical stabilizer with a fully deflected rudder. The stall speed doesn't enter into the equation.
But what are Crock and Buick talking about then since they are claiming some relationship between the two.
