anic:
No stick shakers or warning in the might O. Just buffet. Can actually fly out of a stall, but if you have an assymetric spool up, you are below VMC and this can happen.....
http://www.facebook.com/group.php?gid=5972721339#/topic.php?uid=5972721339&topic=7668
On July 22, a Navy P-3C conducted a simulated engine fire and shut down one of the port engines. Shortly thereafter, the flight crew noticed engine fluctuations in the second engine and shut it down without trying to re-start the first. The plane violently rolled and began a spiraling nose dive at 290 knots.
The pilots allowed the starboard engines to remain at maximum power in spite of NATOPS' requirement to go to "flight idle." A counterclockwise rotation was driven by the stall and the yaw produced by the two engines at maximum power.
The plane was pulling between 5 and 7 Gs and did five spin rotations form 5500 feet before the flight crew was able to restart the first engine and recover at bteween 50 and 100 feet above the deck.
The plane returned to Whidbey without further incident however the aircraft was essentially destroyed -- the fuel tank was ripped open, several panels were bent or buckled, and 45 consecutive rivets ripped out as the starboard wing skin peeled away
