Well, they're not always the same speed. Some planes only have Va, and some have the additional "Turbulence Penetration Speed". In the M20J, for example, Va is from 97 to 116 depending on weight, but Turbulence Penetration Speed is all the way up at 176! Now, I wouldn't fly in continuous moderate turbulence at 176, but there must be a reason for the difference.
Then only thing that I can think of is that maybe they don't expect you to go all the way to the 3.8 Gs that normal category allows. Maybe they figure, "hey, rough air could give them 2.5Gs, and so at 176 they won't exceed that." EXTREME turbulence might give you 3.8 Gs momentarily, so that might be a good time to pull the speed back to Va, where you'd stall before overstressing the airframe (+3.8 - 1.52 Gs). Also, if you were in utility category, theoretically your plane could handle more turbulence (an additional .6 Gs on the positive side) and aerobatic would allow 2.2 Gs more than normal (limited to 6 Gs on the positive end, and - 4.5 Gs on the negative).
That's my guess.
