Mag check
LV-ARG
I was observing a flight in an old 172 and I noticed during the run-up that single mag operations didnt result in any significant rpm drop. At first I thought we had a broken mag ground wire, but then the ignition grounding test killed the engine. Is it possible that the engine continues to work with 2 magnetos when selecting either L or R on the switch but then kills both mags when in the OFF position?
