NewsBot
Administrator
Chantilly Air, Inc. Manassas, Virginia:<BR /><strong>Please Note: If you have applied with Chantilly Air Inc. prior to January 1st, 2018, that application is no longer on file. This is a new position and you must submit a new application along with your resume and cover letter. </strong><br /><br />The Pilot in Command is responsible for supporting the safe, legal, and economical flight operation of company aircraft.<br /><div> </div><div><strong>Location </strong></div><div>Manassas, VA (HEF)</div><div> </div><div><strong>Essential Duties and Responsibilities</strong></div><div> </div>The following statements are intended to describe the general nature and level of work being performed by an individual assigned to this job. Other duties may be assigned.<br /><ul><li>Reports to the Chief Pilot.</li><li>Is the final authority for the safe operation of Chantilly Air Inc. aircraft.</li><li>Performs all duties associated with aircraft operation in a 14 CFR Part 135 operating. environment to include: airworthiness, proper documentation and company manuals onboard, weight and balance computations, weather, performance, fueling, flight locating, briefing, and generally operating the aircraft within the limitations of the manufacturer and company.</li><li>Directs the activities of the Second In Command, ensuring that flight crewmembers understand fully and completely what individual duties they are expected to perform. </li><li>Promotes and fosters a safe operating environment in accordance with FAA and Chantilly Air requirements and proactively contributes to Chantilly Air Inc.’s Safety Management System.</li><li>Adheres to all company policies and procedures. </li><li>Is expected to present a professional image in all environments as a key representative of the company. </li><li>Maintains currency requirements in accordance with FAA Regulations.</li><li>Maintains a 1st Class Medical in accordance with company policy.</li><li>Provides a high level of professionalism and customer service.</li><li>Works closely with and assists in all department duties as needed.</li></ul>
Continue reading...
Continue reading...
