What kind of airplane was it? When we hot loaded the Cessna, it was hard to go towards the prop given the strut was in the way. I've seen the twotter hot loaded for skydiving.... and the prop is right there behind the door.
He should have turned the plane off. Really has no excuse.
On the other hand, I cannot comprehend a situation where I would walk into a prop. How can you be so stupid? Please do not stand up for her. You really must be lacking in common sense and overall SA to walk into a prop. Even if you have barely been around airplanes, you have to be pretty dumb to not realize there is a propeller spinning up there, even if you can't see it. Stand back for 2 seconds and you should realize you shouldn't be up there.
With that said, again, I just don't see how you can walk into a prop without being insanely boneheaded. Maybe I'm being a jerk, but I just don't get it.
With the amount of time I spend around turning props, it isn't something I would guess most of us think about. More of a reflex to always be aware what is in the path of the prop. Not everyone is as conditioned into it, easy to forget I guess..
IF you are going to load and unload without shutting down, there needs to be someone to escort the passengers. It can be done safely, but you need to take some special precautions.He should have turned the plane off. Really has no excuse.
On the other hand, I cannot comprehend a situation where I would walk into a prop. How can you be so stupid? ....... You really must be lacking in common sense and overall SA to walk into a prop.
Aviat Aircraft Inc., Husky A-1C, N62WYWhat kind of airplane was it? When we hot loaded the Cessna, it was hard to go towards the prop given the strut was in the way. I've seen the twotter hot loaded for skydiving.... and the prop is right there behind the door.
A certain large regional airline which had, out of a certain hub, a predominately jet operation but occasionally saw a turboprop airplane, had one of these incidents in the late nineties (if memory serves). A ramper just flat forgot there was a running engine with prop there and was fatally injured as a result.There was an incident several years ago where a line guy marshaled a PC12 to a stop then walked straight into the prop and was killed. You'd think he would've known better but it was late at night and he just reflexively went to chock the nose wheel. It can happen to anybody I guess.
