The answer is.......it depends!
The strength of the head/tailwind in relationship to the aircraft's speed will dictate which one is best.
Let's run some numbers as an example.
Best glide speed = 100 knots
Rate of descent = 500 fpm
Aircraft "A" is at 15,000 feet with a headwind,
Aircraft "B" is at 7,000 feet with a tailwind.
Example #1 head/tailwind = 10 knots
Example #2 head/tailwind = 60 knots
In both examples aircraft "A" will be in the air for 30 minutes (15,000 feet / 500 fpm = 30 minutes) and aircraft "B" will be in the air for 14 minutes (7,000 feet / 500 fpm = 14 minutes).
Example #1;
Aircraft "A" is traveling over the ground at 100 - 10 = 90 knots.
It travels (90 nautical miles / hour)(1 hour / 60 minutes)(30 minutes) = 45 nautical miles.
Aircraft "B" is traveling over the ground at 100 + 10 = 110 knots.
It travels (110 nautical miles / hour)(1 hour / 60 minutes)(30 minutes) = 25.67 nautical miles.
Example #1 it is better to be at 15,000 feet with a headwind.
Example #2;
Aircraft "A" is traveling over the ground at 100 - 60 = 40 knots.
It travels (40 nautical miles / hour)(1 hour / 60 minutes)(30 minutes) = 20 nautical miles.
Aircraft "B" is traveling over the ground at 100 + 60 = 160 knots.
It travels (160 nautical miles / hour)(1 hour / 60 minutes)(30 minutes) = 37.33 nautical miles.
Example #2 it is better to be at 7,000 feet with a tailwind.
So the answer is.........it depends!
