jeflies
You're a new PIC for a 135 on demand charter company. A crew is flying into your home base (maintenance base) on a trip and you will take the aircraft down to Mexico for the remainder of the trip. You arrive at the airport shortly after 9pm and are greeted by the chief pilot, director of maintenance, the dispatcher, and another mechanic. After wondering why everyone is there working so late you ask and are told “A quick line A inspection is needed.” Ah ok, normal routine for a stop at a base.
You overhear the mechanic talking with the director of maintenance about a problem the crew had reported on the plane. Something about a gauge reading improperly? Finally the aircraft and crew arrive and it’s a hustle to get a fast turn so the freight will not be delayed. The PIC closes out the flight log and circles A indicating no discrepancies or MEL items. Goodnight guys!
After a thorough preflight, a fresh line A inspection it’s time to fly! WRONG! After starting the right engine the torque gauge is pegged to its limit. After shutting down the engines, your crowd of co-workers walks up and asks “What’s wrong?” as if they did not already know. After explaining what happened, the mechanics begin to troubleshoot. While they troubleshoot, the dispatcher answers calls and explains the slight delay and assures the customer the freight will be airborne shotly. The chief pilot confronts you and chats a bit. After 5 minutes they inform you it’s probably just a loose wire and it should be working. After another start up its obvious it is not working.
At this point you realize the aircraft is not airworthy. You question the dispatcher about the previous crew’s actions or knowledge with the problem. You’re told they informed dispatch of the “issue” on their previous fuel stop but neglected to write it up.
Now your name is signed onto the current log page for an “airworthy” aircraft that isn’t quite so. Do you follow your gut feeling and write it up? Do you ignore the gauge and fly it?!? What would you do? You’re the captain…
