Same spot.
You start out with the same forward velocity as the plane, and there is nothing to slow you down while you are "in the air", since the air inside the plane has the same forward movement. You will continue your forward movement right along with the plane. (All assuming steady-state flight. Be a different story if the plane was still picking up speed. Or slowing down for that matter.)
Don't try this in an open cockpit plane....
