JetBlue Early Arrival
  • Thread starter Thread starter Guest
  • Start date Start date
FL410 and 41,000 ft ASL aren't the same altittude depending a barometric pressure, but I don't think it's possible to for FL390 and 41,000 ft ASL to be the same...
At any rate you can't take a 320 up there...
Well if you were to spend a day listening to JFK's Tower feed on-line you'd know that they do get clearances with FL390 in them as expected altitude after 10 mins. Also, Jetblue tends to have several face-in's face-out's from JFK. There's an early morning push, which is ahead of the main JFK push, so unless there's a problem they usually get a fast taxi out. If departures are off 31L, they will usually request and get an intersection departure from K, KK or KA. They always get that on their 10-10.30 am push (which is JetBlue only) and their push just after lunch about 1.30-2.00pm (again JetBlue seems to be pretty much the only aircraft around at these times) Their arrival runs into these out's are pretty easy, because 13L is their side of JFK, as is 31R, and their terminal is just about the middle of that runway, so very short taxi to ramp times. JetBlue's other trick when on a departure push running on the 13's is to request 13L for departure instead of 13R, that saves a good 5 mins or more on taxi time. The only time that request gets refused is when their evening push coincides with the heavy departure push to Europe, and the evening departure internally. Listen to JFK between 6-8pm and you'll se what I mean - they have to open up a second ground control frequency (one for sequencing, and one for metering and notifying ready to taxi). Also JetBlue very carefully schedules their multiple Florida departures in the push to be 5 mins apart from each other - if they push back on time off the gate, then they will gurantee automatic route spacing is correct at the runway, and block the WAVEY departure gate to all other JFK traffic for a good 30 minutes (4 or 5 slots). They get no particular preferntial treatment from the controllers, but you must remember an airline's pilots always know 1. their home base airport taxiways very well; 2. their home base tower controller's and 3. the regular procedures and requests likely to be granted at the airport. If you know those things it all helps to save time, and speed up the operation.
There is one final thing in their favour, A320s are pretty nippy off the ground, so when it is busy and the controller is doing sequencing for departure the A320 will take a little preference over certain other aircraft types, cos over a period you can release more aircraft. Think about it - you have A340, 3 A320's, an RJ, a 767 and a 757 on the ground. To get separation after departure you need to leave 3 mins after the A340, cos it's a slow pain in the a** (to quote a few controllers and pilots). You need 2.5 mins after the 767 and the same for the 757. 1 minute only if going different routes for RJ and A320s. So, what will you do.....
Let's see: the order they called in A340, 767, A320, 757, A320, RJ, A320, that'll take 11 minutes before you are clear of them. But try this: RJ, A320, A320, A320, 757, 767, A340 :
10 minutes. Do that over an hour, and you get 6 more planes in the air!!!!!!
I guess what I'm saying is JetBlue is an efficient operation, pick the right departure slots from JFK, and you can get out without queuing for the runway. JFK is not constantly busy like LGA, and it is more flexible when not busy due to its runway layout.
I'm not too sure about this Flight Level info above - isn't everyone on RVSM these days, I know Europe is?
Moscow to London on a 767, asked the capt. what our cruise was and he said FL360!!!!!!
Does that answer everyone's questions?
From flying on jetBlue before I know that those maps that tell you how high and how fast you are going on your IFE system are not always completly accurate.
Well what about the captain's statemnt. I guess he was wrong too?
I'm gonna go with Amber on this one. JetBlue has to pad their schedules, and I'm pretty sure most airlines do. DOT only counts on-time arrivals, not departures. So, if you push late, you could still be "on time." JetBlue is right next door to Southwest at MCO (little bit of heated rivalry there), so we try to show 'em up whenever we can. Last week, my gate turned two full Southwest flights in the time JetBlue took to turn one of their's. I think they didn't like us laughing at them since they turned the A320's engines straight at us.....
that is awesome!! What is the typical time Jetblue takes to make a turn?
btw...cant stand JetBlue personally...go SWA!
jetBlue is actually right around the industry average of about 45 minutes for a turn. We laugh because it takes them 6 people to turn a plane, and we generally do it with four or less. Granted I'm sore and exhausted when I get home.
An A320 can't go above FL390.
As has been said in this thread numourous times.
An A320 can not exceed FL370.
A Boeing 737 NG can cruise at FL410 likewise a 757,767,777,747 can cruise at that altitude.
I believe that some of those "heavies" can cruise at even higher altitudes.
The Boeing 7E7 will also prolly be able to cruise at FL410.
Matthew
Have there ever been any serious accidents during a Heavy type aircraft, taxing?
Where did that come from?
Matthew
Actually 390
As with all those aircraft you listed, they usually only get there when light, and certainly not for the whole flight unless it's short.
I will consult my friend who has been flying A320s for United for 6 years now about the max ceiling.
I'll get back to you guys if he responds.
Mahesh
It doesn't only have to do with taxi time, or padded schedules. Filling out my paysheets for last month I found that only 3 out of all the days I worked did I end up flying over block (over scheduled) time. The rest of the days I ended up having 15 or more minutes less than was projected. This is because when we are flying, we'll work to get any shortcuts we can (less taxi time with closer runway, take a straight-in with minimal tailwind, climb at low angle (less than 1000' min) to get higher groundspeed, and using your climbs and groundspeed effectively on departure and arrival from the airport. All these combined will help shed off seconds or minutes which it would have taken without using your head to take the shortcuts.
They aren't shortcuts that reduce safety, but they increase customer service by keeping passengers making their connections.
My boss was telling me the other day that they've flown at FL450 in their Lear 45. He said they usually get direct most places since its not as busy up there.
Oh and one thing I've noticed is that when flying above FL300 all pilots ever do is bitc_h about where its smooth. How's the ride higher? The ride here is good. We'd like to fly east for smoother. etc etc it goes on and on.
Yea, thats what I said. A little off topic eh?
RVSM: Reduced Vertical Separation Minimum. It's meant to reduce the vertical separation above FL 290 from the current 2000-ft minimum to a 1000-ft minimum. That should allow aircraft to safely fly more optimum profiles, gain fuel savings and increase airspace capacity.
