Caught this today during my preflight inspection. What do you make of it? Leaky wing tank or careless line guy?
I'm the only guy that flies that airplane, and it wasn't there yesterday (during preflight, anyway...I don't generally do a post-flight walkaround, though I suppose I should). Avgas evaporates quite quickly, and when it does, it leaves the dye behind.Is it dried on like that? If so.... how did no one else catch it sooner?
-Rob
Some do, the late P model 172's and the R and S model 172's have a wet wing, all earlier models have aluminum tanks.Do 172s have wet wings?
I've has experience with a 172 wing tank that the bottom had a leak in it and it looked exactly like that.
Seen this same exact thing except the culprit was a crack in the filler neck. When I caught this, the Mechanic removed the skin from the area around the filler cap and found the weld cracked where the filler neck was attached to the tank. From what I hear it is fairly common.
