1. It's my understanding that unless the aircraft is certified for icing, it's against the FARs to fly into an area of known icing conditions. Although I suppose if it is predicted but none is reported than you had better make yourself familiar with the exact freezing levels, possible temperature inversions so that you can climb to warmer temperatures, and make sure the pitot heat and defroster are working (not that those will help you with structural icing). Oh yeah, and just stay out of visible moisture.
Don't forget about alt air for the engine in case your intakes freeze. I had a DE that was hard core on icing, and I had to be reminded of the alt air.
. On a nonprecision approach, if no FAF is given in the profile view, the final approach segment will begin when the procedure turn intercepts the final approach course. On charts, the FAF is shown as either a "Maltese Cross" or a lightning bolt.
Yes, except no ligtning bolt on a non-precision approach. That's glide slope intercept, therefore. It's on the ILS plates that double as LOC plates, but the maltese cross is your FAF for the LOC approach.
